vcProgram
A program containing routines
Module: vcExecutor2
Children: vcRobotProgram
Referenced by: vcCallProgramStatement.ProgramReference, vcProgramManager.Programs, vcProgramManager.copyProgram(), vcProgramManager.createProgram(), ... (see more)
vcProgramManager.findProgram()
vcRoutine.Program
DescriptionStringRWGets or sets a description for the program.
IsDynamicBooleanRGets whether the program was created during simulation or not.
NameStringRWGets or sets the name for the program.
ProgramManagervcProgramManagerRGets the vcExecutor2.vcProgramManager
PropertiesvcPropertyContainerRGets the properties of the program.
RoutinesvcList[vcRoutine]RGets a list of contained routines
StatusvcProgramStatusRGets the current vcExecutor2.vcProgramStatus.
createRoutinevcRoutineOptional Keyword[name = String]Creates a new routine.
Optional: name (str): Name for the new routine.
vcProgram: The new routine.
ValueError: When the routine name is reserved.
deleteNoneNone"
Deletes the program.
None
None
ValueError: When attempting to delete a non-dynamic program while the simulation is running.
NameParametersDescription
OnRoutineAddedvcRoutine programTriggered when a routine is added to the program.
program (vcExecutor2.vcRoutine): Added routine instance.
OnRoutineRemovingvcRoutine routineTriggered when a routine is about to be deleted from the program.
routine (vcExecutor2.vcRoutine): Deleted routine instance.
OnStatusChangedvcProgram program,
vcProgramStatus status
Triggered when the program status has changed.
program (vcExecutor2.vcProgram): Subject program.
status (vcExecutor2.vcProgramStatus): New status.
